Okay so strange issue with Windows 7 on my HTPC. I suspect failing hardware but the issue is bluescreen.
This machine is not overclocked.
Hardware:
GTS 450 stock clocks
i5 750 @ stock
G.Skill Pi ddr3-1600 @stock (1.6v)
Zotac H55 ITX-WIFI
2x2tb green drives (one clicks but passes SMART, both are being replaced with WD black's)
1x30gb OCZ Agility r1 drive.
Use of the machine:
I use XBMC for watching movies, tv, anime, whatever. I have
[email protected] running 24/7 on the GTS 450.
What I'm doing when the issue occurs: Anything, from sitting at the desktop with everything disabled to watching a movie.
The issue itself:
I'll get a bluescreen, when the computer autoreboots from the bluescreen either
A) My Bios hangs at ACPI Port 3 (SSD is plugged in here) for aabout 20 seconds and I go to a black screen with blinking cursor in the upper left
or
B) My BIOS post happens instantly like normal and the 2tb drives spin-up as if trying to access something and then I go to a black screen with a blinking cursor
To (temporarily) solve the issue I must manually power down the PC and then power it back on, enter the bios and set the SSD as the primary boot device - without powering down the pc, the SSD is NOT visible within the bios.
I suspect the SSD is dead/dying, is this sound logic?
Things I have tried:
Rebuilding the entire system from the ground up (using different sata ports for all sata devices as well, I also tried smaller steps before this that would be included in this step, but seeing as I have done this I will omit them)
Resetting all Bios settings
Giving more voltage to IOH/ICH, QPI, vCore, DIMMs
Things I have not (and would like to avoid for the time being):
Reinstalling the operating system (I am in the process of, painfully, backing up the contents of the 4tb striped volume created with the windows partition manager to ensure I don't lose the data when I reinstall)
