1 - 13 of 13 Posts
Well, among my EUE problem, smp folding got a WU that said 4 days to complete and the last deadline was 3 days, and the system tray client won't connect to a WU?
are there any solutions? O_O
can you refine your question?
W7 was a PITA to get set-up for [email protected] for me -but, once I got it working- it's been smooth as silk- no errors and no EUE's
My biggest issue was the increased firewall/port-security restrictions! (which is a good thing IMO)
and from your post it seems like you also might be experiencing "connection" issues- try looking at those settings!
-on the other hand- my other two systems (Vista) which have been stable for weeks- have just started throwing NaN's on the GFX and just plain "hanging" on the -smp(s) over the last day or so
(I dropped from 1200+ PPD to 2300
I really need to get everything sorted and back to
before the big day!
Cheers and GL
It may be your CPU isn't fast enough for the SMP client. Have you tried the regular one? Were you able to complete SMP's in XP or Vista? Just a question.
Originally Posted by Taiketo
No problems with GPU2 or the basic CPU client (both tray), but I can't get SMP to work, it crashed during setup and it downloads the work order but doesn't work on it, it just sits at 0%.
Ditto on this, kind of.
I've tried a few methods/attempts to get SMP to work, but I just haven't been able to, so I gave up.
1 - 13 of 13 Posts
