1 - 12 of 12 Posts
Here is the snapshot...
My system is below...
How do I get a rating of 3.0 in the hard disk category?
I have two Seagate 250GB 7200.10 SATA II 3gb/s drives. No jumpers on both drives.
Whats going on?
Strange, I get 6.0. Never had a problem. Make sure write cache is enabled
my brother gets a 5.9 and he has 1 samsung 1TB f1
Discussion Starter · #6 ·
I think I might have found the problem but how do I fix it? Take a look at this...
It's reading the SATA drives as IDE ATA drives:
Anyone know how to remedy this problem?
Could you be a little more specific? How do I make sure its enabled?
Whats going on?
Do you have jumpers on your HDD's set to sata 1.5gbps? Doubt it would matter, but you can check anyway.
Originally Posted by thE_iyE2.718
I used to get 2.8, but I was running a single 250 at 52k
BTW: does vista max out at 5.9?
yes
1 - 12 of 12 Posts
