Windows 7 How to make CTRL+ALT+DEL = Task Manager?
21795 Views 7 Replies 5 Participants Last post by  Prideless
I got Windows 7 recently, how do I make it so when I hit ctrl+alt+del it will bring up the task manager and not make me go to that window where is says lock computer, switch user, log off, change password, task manager?
Thanks.
1 - 8 of 8 Posts
Just use Ctrl+Shift+Esc
or right click the taskbar and left click task manager
Thanks, I think ill do that from now if I cant figure out how to change ctrl alt del.
Also how do I chnage my default system that shows in my sig? I added a new one but dont know how to make it show up.
user cp -> add system or edit system
testing sig.
EDIT: AH HAH! it works now, javescript was on so it didnt work before thought i was doing something wrong.
I just do right click taskbar > Start Task Manager
if im in a game id like the option to bring the task manager up without that screen. but hey ill live if there is no solution.
1 - 8 of 8 Posts
