Windows 7 install problem
2351 Views 23 Replies 10 Participants Last post by  werds
hi, i decided to install windows 7 and i came across a problem. when the i press on install windows button the next screen comes up telling me that some drivers are missing or something but i know all my drivers are updated.. anyone know how to fix this?
p.s: the windows 7 is legit
1 - 20 of 24 Posts
Windows 7 needs drivers for your hard disk to continue the install. Unfortunately your sig doesn't state wich hard disk you have but i suggest you visit the hd's manufacturers site and download the drivers from there.
Hm, try to download the driver again and install it again.
I've never seen drivers for hard disks or DVD/CD drives though..
Hard drives don't have drivers. Storage controller have drivers.
Windows 7 already has the standard AMD, NVIDIA, Intel, Adaptec, LSI, etc storage drivers integrated.
I think you went to insert the drivers into the install (which you do not need to do).
I assume you are doing a clean reformat, so go to Install > Custom > select the partition you want to format > Drive Options > Delete > Next
That should just install it. Try it and get back to us.
This is what I thought.
THat only happened to me on the beta versions... Is it beta?
Could be that you have a Drive that is not supported by windows 7.
That's what I thought as I've never ever seen drivers for them.
How can a drive not be supported by Windows 7? I think every drive (HDD and CD/DVD drive) will work with any operating system. Can't find any reason why a HDD should not be supported by an operating system.
i have vista ultimate right now, i boot up from cd and then go install and the next screen comes up asking me for drivers.. thats it no custom or anything
Most storage drivers are integrated but in a rare occasion windows 7 refuses to recognize the hard disk, This happened when i tried to install 7 on my ancient Dell laptop. I worked around it by first installing Vista wich oddly didn't have that problem and then upgrade to 7 afterwards.
no its not beta
This might have been done already, but did you check to see if the SATA / IDE cables are snug? and if power is in?
Nevermind; forgot
Is this a burned .iso or orginal disk?
That's still an issue with the controller.
I had an HP laptop with "3D Drive Guard" on it, which is basically hardware that stops the drive from spinning if it senses a fall or sudden direction shift. It required me to provide drivers as I would have with a RAID array.
Your system might require similar drivers.
its an iso, i got it from college's website for free. its full version
Ahhhh.... try reburning the .iso at lower rate. I've seen "corrupt driver" issues more than once with burned DVDs. This is even after the disk is verified.
Have you checked for loose cables?
You could try to get a new version just to see if it's Windows itself that's crappy.
EDIT: DuckieHo beat me to it.
Agreed, My point was that the missing driver error was storage device related. Sorry to the op for my bad explenation, blame it on the language barrier
To the op, you might want to install Vista first and then upgrade to 7 afterwards if possible.
1 - 20 of 24 Posts
