Windows 7 keeps doing a disk Check on my D partition
2501 Views 5 Replies 5 Participants Last post by  Crooksy
Windows 7 keeps doing a disk Check on my D partition evertime i boot up the computer.. Everytime nothing is wrong. I even did the disk check manually on my computer>right click D drive scan errors. Nothing was found. Did disk check in CMD. Nothing was wrong.
So is this a way to get Windows 7 to not do a damn disk check on my D drive partition... I get the same message every time i turn on my comp.
1 - 6 of 6 Posts
Are you aborting it every time, or letting it go through?
done both... it just keeps coming back
I have a similar issue with my laptop. Every now and then it checks drive c for consistency. I always let it to the thing ... but it keeps coming back. My desktops, using the same OS had no consistency check for months. I am still waiting for it to show up in them.
yeap, lately my D partition does that too....
dunno why..... annoying as hell
Here, do this.
1. Open a command prompt, note; type only the bold text
2. Type fsutil dirty query c: assuming the volume is c:
3. If the return message reports the volume is dirty type chkntfs /x c:
4. Reboot, note; it should not perform a consistency check and reboot normally
5. Open a command prompt again and type chkdsk c: /r and choose yes
6. Once it is finished repeat step 2
7. If the volume is no longer reported as dirty then reboot and the problem should be resolved
Edit, change appropriate letters to D
1 - 6 of 6 Posts
