Can't think of why that would happen. Try using CMD to convert for you?
You sir are the bombOriginally Posted by trojan92
Open cmd and type diskpart and then enter. Type list disk and press enter again.
Select the disk you want to convert e.g, disk 1 by typing select disk 1.
Seeing as you don't have any volumes on the drive (deleted through Disk Management) just type convert gpt and then enter. This should do the trick for you![]()
You are welcome, glad it worked for you
