Yeahh, I'm running 4GB of ram (800MHz Dual channel, 2x 2GB) on Windows 7 32-bit.
At factory settings, it said 4GB were installed, but only 3.5GB were usable.
On the boot splash screen's memory check it said 4096MB were okay. Fair enough.
I then applied the 4GB patch. Which solved the problem. I now have 2 operatings to choose from - Windows 7 Test version >128GB (default) and Windows 7.
Everything was going well, until I decided to overclock my RAM to 1066MHz.
Now, on the boot slpash screen it says 3522(or something)MB were OK, and when I boot into the patched OS, it says 4GB are installed, but only 3.5GB are usable, and when I boot into the unpatched version, it says 4GB are installed but only 2.7GB are useable.
This stays the same, even if I revert to 800MHz. I've tried re-applying the patch, but it would be nice to know how to fully remove it and start over.
What do I do?
Oh, and sometimes my wireless connecto goes inactive and my PC starts going slow as hell. This IS to do with the ram problem, because it only happens when I boot into the patched version.
Thanks,
Dan.
