The key will only activate if the upgrade option is used, a fresh installation is not possible.
If you would like a fresh installation without using a prior installation vista or xp to upgrade from simply do a fresh install using the upgrade disk, then upgrade the clean install you just did (so the key activates). Works like a charm. Imo it is the only upgrade option that isnt FAIL.
