PART 3
Click on the
Startup Repair link from list of recovery tools in System Recovery Options.
As you can see, several other diagnostic and recovery tools are available in the Windows 7 System Recovery Options including System Restore, System Image Recovery, Windows Memory Diagnostic, and Command Prompt.
In this guide, however, we're only repairing
operating system files using the Startup Repair tool.
The Startup Repair tool will now search for problems with important Windows 7
files.
If Startup Repair finds a problem with an important
operating system file, the tool may suggest a solution of some kind that you have to confirm or may solve the problem automatically.
Whatever happens, follow the prompts as necessary and accept any changes suggested by Startup Repair.
Startup Repair will now attempt to repair whatever problems it found with Windows 7
files. No user intervention is required during this step.
Important: Your computer may or may not restart several times during this repair process. Do not
boot from the Windows 7 DVD on any restart. If you do, you'll need to restart immediately so the Startup Repair process can continue normally.
Note: If Startup Repair did not find any problem with Windows 7, you won't see this step.
Click the
Finish button once you see the
Restart your computer to complete the repairs window to restart your PC and start Windows 7 normally.
Important: It's possible that Startup Repair didn't fix whatever problem you were having. If the Startup Repair tool determines this itself, it may automatically run again after your computer restarts. If it does not automatically run but you're still seeing problems with Windows 7, repeat these steps to run Startup Repair again manually.
If it becomes apparent that Startup Repair is not going to solve your Windows 7 problem, you do have some additional recovery options including a System Restore or a System Image Recovery, assuming you have previously backed up your entire computer.
You could also try a Parallel Install of Windows 7 or a Clean Install of Windows 7.
However, if you've tried a Startup Repair of Windows 7 as part of another troubleshooting guide, you're probably best served by continuing with whatever specific advice that guide is giving as your next step.
(c) and credit goes to Tim Fisher, the author of this extensive guide.
