Windows 7 will not shut down
1313 Views 1 Reply 2 Participants Last post by  Lunchbox21984
I've been having this little problem for a while now. When I try and shut down Windows 7, it hangs at the 'Shutting Down...' screen forever. It will never advance beyond it, and I just have to turn off power at the PSU.
Since it started I've gotten a new PSU and have even reformatted and I have the same issue. The only thing that seems to correlate with this starting is my 4850x2 2gb card I got, I think the problem started right around when I installed that.
Anyone have any ideas?
1 - 2 of 2 Posts
it does not sound like the videocard is at fault here. everyonce in a while, mine will not shutdown either and i think its windows itself. double check too see if you have all the updates as i think it was an update that fixed my issue, because it hasnt done that in a while sense a few updates came out.
good luck
1 - 2 of 2 Posts
