windows 7 with p31?
347 Views 8 Replies 5 Participants Last post by  D3TH.GRUNT
as u can see ppl i have windows 7 and my motherboard is p31..
i want the drivers for this motherboard on windows 7... anyone can help?
;;::i think this is the best place for the thread::;;
1 - 9 of 9 Posts
the drivers shoul;d be downloaded automatically during the installation why do you need the drivers for the mobo anyways?
anyways, if you do download them manually, you should grab the vista x64 drivers for win 7 x64. they ought to be on the gigabyte website
the audio driver ( realtek audio ) says that i can run it only in vista...
thats why i search for the mobo driver..
i tried windows update ...no use
Yes, use the Vista drivers and run them in Windows Vista compatibility mode if they won't install.
they install well but when i try to open my Audio centre from the tray it says that i only can open it in windows vista
That is mainly cause it is a beta. If you want Windows 7 to work perfectly, wait for it to be fully released, with the proper drivers fully supported.
when it is gonna be officially released?
and thanks
maybe at the end of this year, or early next year.
1 - 9 of 9 Posts
