1 - 8 of 8 Posts
Originally Posted by frW;13059262
I don't use Turbo Boost.
@Doom, okay, as I figured then. Nothing to care about. It's a bit annoying though.
Agreed, last time that worked properly was XP 64 for me (skipped Vista totally).
When you say BIOS do you mean the speed you set in the BIOS or just what windows is gleaning of the BIOS at start up ?
When my computer starts up and bios is initating it says "BIOS speed 24*160 = 3.8GHz" and "OS Speed 25*160 = 4.0GHz".
Originally Posted by renaldy;13059290
that's because window can only detect up to 21 multiplier, and you have 25 multipler. just use cpu-z
my pc is the same window is detecting my overclocking 4.2ghz and i have 4.5ghz in cpu-z
Thanks, that explains it.
1 - 8 of 8 Posts
