1 - 12 of 12 Posts
I already have a router that does most of my firewall stuff, so if I just use Windows firewall will it be enough?
It's just for my gaming PC (I don't even log into my emails on it), which knowing my "sources" it might already have a virus, I don't care that much as long as it doesn't slow things down.
Windows firewall is crap. If you have a decent router with with a hardware firewall built in dont worry about it.
Just disable windows firewall all together, if as I mentioned, you have your router firewall enabled.
For the longest time i have been using just a firewall on my laptop and i've been fine. I would recommend having CCleaner though. It will definitely clear some crap you might pick up from the internet.
If you do decide to get an anti-virus, go with AVG. It's free and i can't even tell its running. I recently installed it on my laptop. I didn't want to but I decided i probably should. With my semi-low laptop specs, I couldn't believe it still ran fast even with AVG at startup and while running the laptop.
If you're that concerned, you could go the virtualization route and have a virtual guest OS on your workstation that you use for various internet activities. If the virtual machine gets infected, it's a helluvalot easier to restore to a previous state, or even just build a new one....
That's what I do - My gaming system / workstation just purrs along running games and what not. All the surfing and "normal" work is done on a virtual machine...
Yup, it's called snapshots.
1 - 12 of 12 Posts
