1 - 12 of 12 Posts
Can't click on anything. Can't ctrl+alt+dlt. Whenever I try to bring the Taskbar up or click on the shortcut it just gives the circle wait thing.
It boots into Safe Mode fine, and I ran the memory diagnostic, everything is fine there.
Check Disk is next.
What else could it be?
Storage Nut
usb external plugged in? Ran ccleanup or disk cleaner and defrag?
No, just KB/mouse/LAN/toslink plugged in the MB.
Originally Posted by Fishinfan
Have you defraged your driver recently? Or ran a program like ccleaner to clean your drive?
I haven't defragged anything, this is a fresh 6 hour Windows install. No CCCleaner ran.
Not OC'ed either. Everything is bone stock.
Storage Nut
Reactions: Segovax
Are the newest intel sata drivers installed?
Not sure, gonna go check now, I just used the MB disc for drivers. Thanks.
Storage Nut
Also, crucial M4 firmware up to date? http://www.crucial.com/support/firmware.aspx
And bios?
Also, go to system config and check to see what programs and services are bing loaded at boot.
I had an issue similar to yours when I first installed window. It worked it's way out with the sata and firmware updates.
Wait, so Safe mode was fine? Any additional programs installed after windows?
edit- also, is this your rig in your signature, or another one? and how long exactly does it take to start up that we're talking here.
Discussion Starter · #11 ·
It must have been one of my SATA drivers. Crucial is on 0009.
Disk check came back clean, and I installed every single updated driver I could find for the whole damn board while I was in Safe Mode.
Thanks Sean, it's all good now.
I'm gonna check out driver detective too Fish, thank you.
Storage Nut
Sweet! Glad to help! lol
1 - 12 of 12 Posts
