1 - 20 of 20 Posts
I'm sure you get these a lot, but I'm stumped. I just got a new MOBO, CPU, and GFX card. The MOBO is an ASRock 939Dual-VSTA, and the hard drive is a Hitachi SATA150. I had this hard drive working just fine with my old motherboard, and this MOBO has reccognized my IDE one, that's what I'm using right now. I tried this boot disc that came with the hard drive, but all it does is format it, and it did nothing. I also tried both my SATA150 port things. The BIOS reccognizes it and everything, but just Windows doesn't. Anyone have an answer for me?
Could be bad SATA cables.<br><br>
I had to replace my old SATA 150 cables and they were new <img alt="" class="inlineimg" src="/images/smilies/eek.gif" style="border:0px solid;" title="EEK!">
<div>Originally Posted by <strong>dizzy4</strong></div>
<div style="font-style:italic;">Could be bad SATA cables.<br><br>
I had to replace my old SATA 150 cables and they were new <img alt="" class="inlineimg" src="/images/smilies/eek.gif" style="border:0px solid;" title="EEK!"></div>
</td>
</tr></table></div>
My BIOS recconizes it.
format the drive? that may help windows recognize it easier <img alt="" class="inlineimg" src="/images/smilies/confused.gif" style="border:0px solid;" title="Confused">
Discussion Starter #5
<div>Originally Posted by <strong>TheEddie</strong></div>
<div style="font-style:italic;">format the drive? that may help windows recognize it easier <img alt="" class="inlineimg" src="/images/smilies/confused.gif" style="border:0px solid;" title="Confused"></div>
</td>
</tr></table></div>
I did... I said that in my first post.
is it a backup drive? do u have another hard drive with an os on or are you at the install stage
Discussion Starter #7
<div>Originally Posted by <strong>biatchi</strong></div>
<div style="font-style:italic;">is it a backup drive? do u have another hard drive with an os on or are you at the install stage</div>
</td>
</tr></table></div>
I'm using only an IDE right now, which is... ok, but I need this SATA, cause I only have 10 gigs left on this IDE, and I haven't even installed games yet. <img alt="" class="inlineimg" src="/images/smilies/frown.gif" style="border:0px solid;" title="Frown">
go to control panel/ admin tools/comp management/disk management/see if it shows you your sata drive if it does right click on it/change drive letter and paths/add that should sort your problem
Discussion Starter #9
<div style="font-style:italic;">go to control panel/ admin tools/comp management/disk management/see if it shows you your sata drive if it does right click on it/change drive letter and paths/add that should sort your problem</div>
</td>
</tr></table></div>
I had already checked that, and it doesn't show up, and it doesn't show up on the Devices list either.
you could try a linux live distro see if that pick it up ok. otherwise im out of ideas
Did you get the sata drivers and F6 them into your windows install?
Discussion Starter #12
<tr>
<div>
Originally Posted by <strong>Ch13f121</strong>
</div>
<div style="font-style:italic">Did you get the sata drivers and F6 them into your windows install?</div>
</td>
</tr>
</table>
</div>With the SATA drivers... I reboot, and it just freezes on the start up screen.
Well i had the same problem go to system hardware devices and uninstall all of the Ide and raid/sata controllers.<br />
Windows should do it automatically.
Discussion Starter #14
<tr>
<div>
Originally Posted by <strong>TooFAST4YOU</strong>
</div>
<div style="font-style:italic">Well i had the same problem go to system hardware devices and uninstall all of the Ide and raid/sata controllers.<br />
Windows should do it automatically.</div>
</td>
</tr>
</table>
</div>The only hard drive related drivers on here are from Microsoft, the problem is, Windows isn't seeing this hard drive at all. Even when I was trying to install Windows, it couldn't find that hard drive.
Discussion Starter #15
Anyone else have any other ideas? I'd really like to get this working so I can try a game on this new graphics card of mine.
like i said try a linux distro to check that there isnt a problem with your hard drive
Discussion Starter #17
Got it working, not sure what did it though. I tried several different things, then tried the Windows install disc, and it reccognized it, so all is good.
he already tried that enterprise
Administrator
<div>Originally Posted by <strong>radbirts</strong></div>
<div style="font-style:italic;">Got it working, not sure what did it though. I tried several different things, then tried the Windows install disc, and it reccognized it, so all is good.</div>
</td>
</tr></table></div>
Missed that. Nice great to see you got it working.
1 - 20 of 20 Posts
