try a spyware scan. Spybot Search & Destroy and Ad-Aware SE Personal are very good programs. Install them, update the definition files, and run them in safe mode with command prompt. Give us an update after you do this.
Originally Posted by b0gEy I ran adaware in safe and reguler mode. It found to two tracking cookies. Nothing else ![]() |
Originally Posted by klewiss Try "Safe mode with command prompt". Use task manager to load programs (ctrl+alt+del). Also run Scandisk and select both options "Automatically fix file system errors" and "Scan for and attempt recovery of bad sectors". I had a problem similar to thisand scandisk solved it. ![]() ![]() And have you OC'd your CPU? |
