1 - 5 of 5 Posts
I put the logitec software to run at startup and hold my setting and so far it is not... it doesnt run at startup for some reason.
check msconfig?
I checked it, turns out I had the wrong link, im a moron... is there any way to have it startup but not acually open, like it just goes in the tray?
Discussion Starter #4
Yea I dont know if its possible either, but it never used to actually pop up at startup it just ran in the tray hmm
that would be a setting in the app itself. ie. start maximized or minimized.. check the prefrences.. <br />
<br />
matt
1 - 5 of 5 Posts
