Windows not recognizing Phenom II 920
458 Views 4 Replies 3 Participants Last post by  echohunter
I got all my parts yesterday. Built the whole thing without any problem. For now I installed Windows Xp on it but there is a problem. windows is not recognizing the phenom II 920. when I go to device manager and look under processor it just says AMD processor model unknown but cpuz recognizes it. Is there a fix to this problem?
1 - 5 of 5 Posts
"Unknown CPU Type" is just a BIOS thing and shouldn't make any difference how the cpu runs.
Check and make sure the BIOS version you use supports the CPU, if not - see if there is an upgrade that does.
It's possible that your motherboard didn't originaly support that speed of CPU either.
Sounds like you might need a BIOS update. Some motherboards needed them to support Phenom II chips
I would check the support forum of your motherboard manufacturer to see if there is an update the Phenom II line.
ok I will try to update the bios as soon as I am finished with what I am doing now, I will post back if it works. Thanks
yep.. bios update did the job. Thanks for all the help
1 - 5 of 5 Posts
