Windows problem BSOD - Help
258 Views 4 Replies 2 Participants Last post by  wiggy2k7
Hi OCN,
My friend has got a problem with his laptop it wont boot into windows in normal or safe mode. He gets a BSOD unmountable boot volume 0x00000ED.
So i thought it would be a quick boot from XP disk and repair the boot sector/mgr from the command prompt/repair console. Only problem is that the repair console isn't detecting his C:\\WINDOWS partition, all i get is just E:\\MININT which is his backup partition. Strange...
Any ideas ???
Thanks
1 - 5 of 5 Posts
The partition is damaged, probably beyond repair. You may have to repartition, reformat, and reinstall.
Yep, i tried to repair it but it wasn't repairable, im formatting as i type this... See how it goes, hopefully the hard drive is ok
It may be. Good luck.
I formatted and reinstalled windows and now its fine now.
1 - 5 of 5 Posts
