So I received my 2x 1GB sticks and decided to make the system be a little easier on my HDD by turning off the Windows Virtual Memory or Pageing File... So I went to the Performance thing and turned off the virtual memory and clicked set then restarted my computer. It shows in there that the currently allocated paging file is 0MB which I want but then if I go into Task Manager and look at the Virtual Memory usage everything is using it. Howdo I turn it totally off? The image attached shows the problem with it showing none allocated but then it is using some in task manager.
