The main difference is the amount of RAM the OS can reference. 32 bit tops out at just over 3 Gig, while 64 can go to something like 16 Tb. I don't think we'll be needing that much ram for a while... but hey, ya never know.
wow thats alot of ram is there even a motherboard that can support 128gb of ram
They've been experimenting with ram in the 100+gb for a while now, but for home applications I think it will be a long time before we see the need for something like that. Needless to say, it won't be the OS holding back the memory down the road...
Vista 64 Premium only supports 16GB. Vista 64 Business and Ultimate only support 128GB. These are artifical limits set by OS developers. A 64-bit can actually support 2,097,152 terabytes.
64-bit Vista has slightly improved security (only slightly).
64-bit Vista can also run application in 64-bit! These are usually MatLab, Maple, and other scientific/math applications.
Just to get this right. Is 32 bit and 64bit install all available on one disk or seperate ? as I thought they where seperate but know im getting other statements thats not true lol
I'm pretty sure 32 bit and 64 bit are on different disks. However you can install any variation of Vista (i.e. Home Premium, Business or Ultimate) from one disk.
It's a question of what your key works for.
i currently have the 64 bit and it has a lot of issues, because not everything is designed to run on 64 bit.
32 bit you should get almost everything to run on it.
to my knowledge all vista's are the same, its the key that determines which one you are installing ( business, home, ultimate, etc). but x86 and x64 are on separate disks. atleast mine are.
I have the 64 bit version, found no problems with it being 64 bit. Haven't had any issues running 32 bit software. My kit came with 2 discs, one for 32 and one for 64.
really? my audacity doesn't want to work, along with some movie editing programs like adobe premiere and premiere elements.
games like cs work fine though.
1 - 13 of 13 Posts
