You got a crap load of processes running. I'm running xp64 this is my idle process list.
Never heard of searchindexer.exe before. I guess going into you msconfig, unchecking all the start up processes, uncheck indexing service, and then hide all microsoft services and unchecking all those extra services except for your video drivers service.
Edit: Opps, forgot to exit Last.fm. So thats 21 idle services.
Also you said this happened after you installed your audio drivers, no?
Go into your sound properties, and somewhere in there(i think under advanced or something like that) there's something about audio enhancements. Disable it. If that doesn't work or has bad side effects, try uninstalling your sound card drivers. Creative makes the worst drivers EVER IMHO. + XP 64 support isn't that great from what Iv'e heard.
ughh, i have no addons for firefox its a fresh install yet it hogs all my memory? anyways i deleted it still have the problem i also deleted my audio drivers.. a computer running with 2 megs of ram and a 10 mhz cpu is faster than what mine is right now so annoyingggg for once im stumped will rep you guys but pc is too slow i'll do it later :swearing:
Overclock.net
