1 - 4 of 4 Posts
As you might of know in my other post I was going to install windows xp on my dell inspiron 2500. So I did, It booted up fine and everything worked, I installed my network adapter drivers and it prompted me to reboot, So i thought that was normal, I showed the boot screen and looked normal, I was waiting to see the welcome screen but nothing, I could here the windows xp start up chime, So I booted into safe mode and I could see everything and everything was running properly, I downloaded the latest driver for my gfx card and installed them, I thought it was a driver problem but nope, still did not work, I have a dual boot config on this machine (Windows XP + Windows 2000).I partitioned 110gb's of my 160gb Hard drive for test, Windows 2k runs with no problems at all. Can you help???
Thanks,
Wamthesuperwam
It's a wireless g network adapter,
I uninstalled them and it works thanks
Wamthesuperwam
1 - 4 of 4 Posts
