Hi guys
I have a Winfast PX8800GTX that started artifacting a lil while ago in some games, at stock speeds. then it stopped screening alltogethor. the PC still beeps, i tried it in a diff pc. no luck.
So i decided to check i9f the core and mem are getting voltage. i used these measure points with my DMM and the mem is getting 1.96 volts and the core is getting 1.3 volts. so voltage seems to be getting through fine.
Im puzzled as to what it can be. the card still seems to be alive in a way. its getting voltage 2 core and mem, and if i unplug 6 pin cables and try start it then it makes the long beep which means power shortage. so it seems to be alive still. but no screen.
Any help appreciated, or any points i should measure with my dmm to check if its a voltage problem
Thanks
Thanks
