So here are the issues (and this is not one of my own computers, but one I'm building for my boss, so don't rely on my sig-rig for any assumptions)... I currently have four updates that Windows Automatic Update has been trying to install, or rather has installed more than once. Essentially, it tells me I have downloaded updates and asks me if I want to install them, I say yes, it "installs" them, then a couple minutes after finishing the installation, it tells me I have updates to install, and guess what? They're the same ones... and this is a repeating pattern so long as I continue to click "yes" to installing them. Problem two is that when I go to the Control Panel, and try to open the Security Center to try and turn off automatic updates, the computer quickly crashes and restarts. That's happened the last three times I've tried it. However its only happened the last three times, and only since I noticed this repeating update installation. The only thing that you should know if that I had a few hiccups earlier today while installing updates, and the computer froze up mid-updating... I let it try and take its time to finish, for at least an hour and a half (thanks to a baseball game), and when I checked back it was on the same update with no mouse movement... had to restart the computer with the reset button... and this happened two separate times during updating.
So what do I do? Seriously, this computer has simply been an evil black box of drama ever since the beginning of the project, but there's no money to fix/replace parts unless it comes out of my own pocket. I've had video card issues up the yin-yang, at least before this last fresh reformat and OS install, and I'm about to test it out again (hopefully with no problems, because that would mean a GPU RMA). But what about the issues up above? Any thoughts on what to do next...?
