1 - 3 of 3 Posts
I just sold a PC and I need a program to completely wipe one of the HD's. I would like to do it from windows, it is just a secondary drive. Does anyone know of a good free one I can get? I would like to start this ASAP, so I can go to bed and have it done in the morning(not sure hoe long it takes).<br><br>
Thanks
Just right click on the drive and press format.
Alternatively, you could try something called Clean Disk Security. It has several levels of cleaning (1 pass with a simple write pattern, up to a Guttman 35 pass write with random characters). I would suggest formatting the drive, then running Clean Disk Security on it at the NIS mode (which is 7 passes of randomized characters). It will take some time, but it's the most secure deletion method I have used. The only problem is, I don't know if it's still free or not. <img alt="" class="inlineimg" src="/images/smilies/frown.gif" style="border:0px solid;" title="Frown">
1 - 3 of 3 Posts
