Wireless adapter issues
238 Views 1 Reply 2 Participants Last post by  cchalogamer
I run a Linksys Router WR45G without issue. I'm hardwired and 3 other rigs use wireless adapters. One rig is recently acting up. The signal strength is excellent and is turned on for approx. 5-10 minutes and then automatically firewalls itself even though it's still turned on with excellent signal.
I manually turn off the firewall but the rig still can't surf or get a signal. I've been through XP Support without avail.
I've also reset the modem and router to no avail.
I don't have these issues with the other wireless rigs.
Any ideas?
1 - 2 of 2 Posts
Does it still show as having a valid ip address? If not try setting it up static if so, possibly try swapping wireless cards in it and one of the others to see if that has any effect.
1 - 2 of 2 Posts
