1 - 3 of 3 Posts
New to OCN?
I have recently noticed that all the download from any source have a 40% lower speed(before I was using the same usb wireless adapter and I had full speed)how can I check if it is a software limit or something else?
Programmer
What speed does the router normally sync at? Check the current sync speed to compare. Information can be found by logging into the router. This will rule out an issue at the router end. However I suspect it to be either an isolated issue with the PC in question or a fault with the USB wireless.
Programmer
After our Steam discussion, I am more than certain the Wireless USB is at fault since the speed reduced when plugging it into another device. Prior to that, the alternate device functioned correctly with it's own internal Wireless reciever.
1 - 3 of 3 Posts
