I hope i can post this in this section...
Anyways, im building some paper plate speakers for the lulz and i want to check on some things with you guys.
]Is more windings of smaller diameter wire more preferable than thicker wire? I figured more smaller gauge wire would give greater impendance.
And now the issue of wiring.
Well i have like 3 magnets and a 3.5mm jack cable just lying around so ill use those, but i need help with wiring.
I bet the anwser to this one is stupidly simple or just "you cant do this", i hope you wont cringe at my lack of knowledge on this matter.
