1 - 14 of 14 Posts
Just a few days ago i reinstalled windows on my pc and i downloaded WMP 11 beta 2 and now i want to roll back and install WMP 10 but it don't do it?? it says rollback is complete but it's still Media palyer 11 thats there so i can't install 10 that being a older version
Ive seen people having this problem before. Sometimes it has problems and you cant' roll back. Since you reinstalled a few days ago if its not to much trouble for you and if you really dont want wmp11 then I would suggest go ahead and reinstall.<br />
<br />
Sorry if this doesnt really help you.
Just goto <b>Add & Remove Programs</b> and let it load - tick <i>"show updates"</i> and scroll down to WMP 11 Beta, uninstall it WMP 10 will automaticly be back <img src="/images/smilies/smile.gif" border="0" alt="" title="Smile" class="inlineimg" /><br />
<br />
<img src="http://img57.imageshack.us/img57/9817/hereek1.jpg" border="0" alt="" onload="NcodeImageResizer.createOn(this);" />
Discussion Starter #4
i never had wmp 10 on i had the version you get when you install xp and although i click remove wmp 11 i get the rollback complete message but when i fire it up it hasn't changed? it doesn't bother me too much if i have to use 11 but i would like 10 if i could.
Thats very weird <img alt="" class="inlineimg" src="/images/smilies/thinking.gif" style="border:0px solid;" title="Thinking"><br><br>
What are you using to uninstall?<br><br>
Try the trial of <b>MyUninstaller</b> It has a complete unstaller including removing unused folders for the app + registry info <img alt="" class="inlineimg" src="/images/smilies/smile.gif" style="border:0px solid;" title="Smile"><br><br>
Hope it works<br><br>
Mad
Discussion Starter #6
i used MyUninstaller but nope just does the same thing. would just using my xp cd and using repair windows option revert it back to its normal version
<div>Originally Posted by <strong>machinewashable</strong></div>
<div style="font-style:italic;">i never had wmp 10 on i had the version you get when you install xp and although i click remove wmp 11 i get the rollback complete message but when i fire it up it hasn't changed? it doesn't bother me too much if i have to use 11 but i would like 10 if i could.</div>
</td>
</tr></table></div>
Since you never wmp 10 you wont be able to rollback to my knowledge, just reinstall windows.
<div>Originally Posted by <strong>blackeagle</strong></div>
<div style="font-style:italic;">Since you never wmp 10 you wont be able to rollback to my knowledge, just reinstall windows.</div>
</td>
</tr></table></div>
Or use Winamp <img alt="" class="inlineimg" src="/images/smilies/tongue.gif" style="border:0px solid;" title="Stick Out Tongue"><img alt="" class="inlineimg" src="/images/smilies/gunner2.gif" style="border:0px solid;" title="Gunner2"><img alt="" class="inlineimg" src="/images/smilies/gunner.gif" style="border:0px solid;" title="Gunner">
Discussion Starter #9
</td>
</tr></table></div>
Ok i'll just keep it, i don't wanna reinstall windows again just for the sake of not having wmp 11<br><br>
Oh and one quick question, i have a two disc album in mp3 on my comp but media player won't play it it says "Windows Media Player cannot play the file. The Player might not support the file type or might not support the codec that was used to compress the file" but it is just MP3 i had it playing before and it works using media player classic but i never use that
Administrator
Sounds like a Registry error. Try the above after running Registry mechanic found here : <a href="http://www.pctools.com/registry-mechanic/?ref=google_rm" target="_blank">http://www.pctools.com/registry-mechanic/?ref=google_rm</a>
I had this same problem because I did'nt have WMP10 on my PC I could not roll back and WMP11 the little **** wont uninstall in the normal manner...<br><br>
Anyways this is how you remove it... <a href="http://www.overclock.net/other-software/120141-wmp11-uninstall.html" target="_blank">Posted by Sin100</a><br><br>
Windows regestry > HKEY LOCAL MACHINE > SOFTWARE > MICROSOFT > WINDOWS > CURRENT VERSION > UNINSTALL<br><br>
When you expand the Uninstall folder, you'll see all the programs currently installed, such as the uninstall Media Player 11 or Media Player, etc.<br>
Click on the folder you want to uninstall, in the box on the right you will see two strings, DisplayName and UninstallString.<br>
Double click UninstallString and a box will appear with the uninstall string highlighted.<br>
Right click on the highlighted entry and select COPY.<br>
Close the Regedit window.<br>
START > RUN, Right click inside the command box and paste the uninstall string and click OK to uninstall Media Player 11.
Administrator
<tr>
<div>
Originally Posted by <strong>DeaDLocK</strong>
</div>
<div style="font-style:italic">I had this same problem because I did'nt have WMP10 on my PC I could not roll back and WMP11 the little **** wont uninstall in the normal manner...<br />
<br />
Anyways this is how you remove it... <a href="http://www.overclock.net/other-software/120141-wmp11-uninstall.html" target="_blank">Posted by Sin100</a><br />
<br />
Windows regestry > HKEY LOCAL MACHINE > SOFTWARE > MICROSOFT > WINDOWS > CURRENT VERSION > UNINSTALL<br />
<br />
When you expand the Uninstall folder, you'll see all the programs currently installed, such as the uninstall Media Player 11 or Media Player, etc.<br />
Click on the folder you want to uninstall, in the box on the right you will see two strings, DisplayName and UninstallString.<br />
Double click UninstallString and a box will appear with the uninstall string highlighted.<br />
Right click on the highlighted entry and select COPY.<br />
Close the Regedit window.<br />
START > RUN, Right click inside the command box and paste the uninstall string and click OK to uninstall Media Player 11.</div>
</td>
</tr>
</table>
</div>Wow Nice one. Ill have to keep that for any future reference.
Discussion Starter #13
i'll try registry mechanic see if that fixes things
Discussion Starter #14
<div>Originally Posted by <strong>Originally Posted by DeaDLocK</strong></div>
<div style="font-style:italic;">I had this same problem because I did'nt have WMP10 on my PC I could not roll back and WMP11 the little **** wont uninstall in the normal manner...<br><br>
Anyways this is how you remove it... Posted by Sin100<br><br>
</td>
</tr></table></div>
ok i got it to uninstall now i'll put 10 on and see if my album will play<br><br><br>
*edit* i managed to get my album to play not sure what the problem was but everythings ok<br><br>
Thanx for the help
1 - 14 of 14 Posts
