1 - 16 of 16 Posts
I ran 3dmark05 and got a score of 3462, overclocking the graphics card to ultra speeds and bringing my cpu to 3.3 brings it to 3674. Seems very low as stock 6800gts are scoring 6000s
Downloading 83.10 beta drivers. oh btw, Orb says my graphics card is running at 11 mhz, i know thats not right but just letting you know
Discussion Starter #6
3399 with new drivers and 420 core and 1275 mem, before you say its unstable, it is, no artifacts. at 400 core and 1100 mem, it get 3367
Well what kind of games do you play? Start those games with the graphics on what you feel suits your systems power. If you can run those settings with good frames per sec then don't sweat it. Benchmarks just give you your system's power in terms that are easy to compare, numbers, But we all know what matters most is how it performs in gaming. If it's alright at games then don't sweat it
Need moar megahertz
I'm gettin 5100 default and 6450 fully ocd(cpu and vga).Have you tried other benchmarks like 2001 or 2003 are you scoring low on those aswell? And sure thats a 6800gt? not 6800?
Originally Posted by emericaskater232
yea im sure its a 6800gt, i get in the 5000s in 3dmark03.
In your bios, is the AGP port set to 8x?
You should score higher in 3dmark03 than the 5000's. I get almost 15000 in '03, and 28000 in 3dmark01. Something is holding you back.
1 - 16 of 16 Posts
