Wolfdale E8400 CO temps.
1911 Views 25 Replies 11 Participants Last post by  slickwilly
I recently decided to OC my E8400 but my temps have me worried. My cpu is water cooled but with stock settings at idle im getting:
Core Temp: core1 45C core2 45C CPU: 37C
Speed Fan: core0 51C core1 51C
Real Temp : 40C
and its freezing in my room ~60F
seems a bit high for a water cooled system.
1 - 20 of 26 Posts
How about BIOS monitor? I would trust to realtemp, but that's high for a water-cooled system.
I'm 67.2 F ambient and my E8500 (C0) @ 4097MHz 1.28- 1.344v says 41- 42C idle, hits about 51C heavy load.
Idle temp dont mean shiat, run some ORTHOS for 20 min and see what your Load temp stabilize at.
It all depends on you WC set up and how many chips you have in your loop.
Post some specs on your loop please along with your clocks and voltages.
Real Temp 3.0 reads the chips internal thermal sensors and is the most accurate from my understanding.
Bios reports 46-47C
Cpu 1.14v
FSB 1.19v
Stock 3.0 clock
Originally Posted by Hammerdin
Bios reports 46-47C
Cpu 1.14v
FSB 1.19v
Stock 3.0 clock
Need specs on you water cooling gear.
Maybe a photo or two???
Yeah does seem high for stock sets. Use
the Real Temp sensors test and report back.
core1 movement 7
core 2 movement 7
only the CPU in the WC loop (if thats what your asking)
its Alienwares water cooling, not sure what specs your looking for.
take pictures of it and post them. Alienware generally rebrands some of the equipment they put into their machines. It might be a kit.
Well i cracked open my case and theres plenty dust on the radiator, time to clean i guess. Would enough dust cause this? Hope im not wasting your time over dust. Ill clean it up and see if it helps. ill post pics if its not the dust.
Dust can kill any thermal transfer, clean that it out asap and post some results after =D
The E8400 I have also runs hot with water cooling. The temperature senders tend to not work correctly. Real Temp is the most accurate monitor for Intel CPU's. It is adjustable by adding a negative number when setting it up. Ideally the core temp should be around room temperature, but that's rare. It shouldn't be more than 10° C above room temperature with a decent system. A good system puts you 5° C above, an extremely good one at 2° C above. 60°F = 15°C. You may just have to guess & add a negative number to get a true ball park figure.
Yes, a clean computer is a happy computer.
3.9C different than ambient for me WoooHooo!
36-40C idle after the cleaning. Better, but ive read of lower on a stock fan/sink.
thanks for you time guys.
Maybe at idle, idle temps don't mean shiat as i said before. Load temps is where it is. Run Orthos or prime etc and report back with load temps pls.
Anytime my friend
Your sensors could be stuck. Idle temps don't mean a hill of beans with 45nm CPU's. Load it down like pixel said and check load temps. My bet is they don't increase all that much, meaning your set up is fine.
My E8400 runs high thirties idle and low fifties when loaded by Orthos
I am running @ 3.6ghz. with 1.30 Vcore your temps are not that bad.
On a side note my temps are reported in PC probe real temp shows them to be 10 degrees cooler but I do not worry to much about temps unless the go real high.
ran orthos for a bit and under load it was at 52-53C
Those aren't too bad. What size RAD do you have? 120mm 240mm etc.
Realtemp puts my C0 @ 56c during orthos small ffts.
4275mhz @ 1.51v
1 - 20 of 26 Posts
