Wondering if my PSU can deal with a high end GFX card
516 16
I have a Corsair TX850.
I am wondering if I can run a good 200$ card with no issues.
I am not sure exactly how many watts are currently being used, thats the main issue.
1 - 17 of 17 Posts
Will work fine. I don't think you will even use 50% of it's maximum power , with a high end card... If i remember correctly Corsair rated at 450W could handle 550W easily , so a 850W is a true beast
Discussion Starter · #6 ·
Also, another thing, I have two PCI Epress 2.0 slots, but the thing is, there both not x16, the top slot is x16, and the bottom one is x8. Can I SLI anything? What would happen if I stuck a GTX260 on the x16 slot, and my current EVGA 9500 GT on the x8 slot, it says it requires x16, could I SLI or not? Funny thing is, my board says It has Crossfire support. I am not sure if I can.
Don't think sli'ing a gtx 260 and 9500gt is a good idea , even if you have 2xpci-e x16 . And your board is made for crossfire , so you won't be able to sli at all... The best option IMHO would be is to use the 9500 as a physx accelerator , and the stick it into the x8 slot ( won't affect the performance that much) . Correct me if i'm wrong
Edit: It's designed for Crossfire , but can probably do Sli too. Also did some quick research and found out that if you stick a 2nd card , both slots become 8x...
Also if i remember correctly Pci-e 2.0 is 2x faster that pci-e 1.0 , so a pci-e x8 2.0 would have the same speed as a pci-e 1.0 x16 , right? And if that is true then the performance loss will be too small to notice, since we barely cross the pci-e 1.0 speeds
And finally if you use a long card, it will block sata ports, leaving only 2. So a 3rd sata HDD would be impossible in your case
Discussion Starter · #9 ·
If I get a bigger card, I will put it in the bottom one if they run at x8 each, cause I want my satas.
Originally Posted by encore018 View Post
will a 650w corsair run my sig rig?
Yes... The minimum wattage for non-sli setups is around 500w if you have alot of extras (fans, harddrives, led's). For SLI, I'd say 650 watts is enough for most, 750 for those with 7 harddrives, water cooling systems, and major overclocks.
Only quad GPU systems need ~ 1000 watt power supplies.
Sullivan...without a doubt you can run a GPU within that price range!
Encore....you will be fine as well....
For both of you....take a look at this PSU calculator...there are many on the web but here is a start:
Power Calculator
Hope this helps!
a 850TX will run any gpu config pretty much
2xGTX295 would work fine with a 850TX
encore018: a 650tx will do fine with a 285 or even a 295
1 - 17 of 17 Posts
