Wondering What I should Upgrade
667 Views 25 Replies 13 Participants Last post by  -iceblade^
My system is below, just wondering what would be the biggest upgrade..
I'm using XP
1 - 20 of 26 Posts
Another GTS would be pretty good and you could OC your cpu to give you a bit of a boost.
How much do you have to spend?
Because a nice upgrade would be GTX285 Tri SLi.
I'd say a new Harddrive, but that's personal preference.
And I'm pretty sure you can't Tri SLi 8800GTS's... ^
I'm using XP
New mobo, and a sound card, like this extreme music
and another 8800 after you get a 16x/16x board
So a new GFX card would be my best bet? I do have games in mind obviously (not overclocking so much). My mobo is pretty old but has everything you would want and supports me cpu so meh. I just want to play the next gene games as it would be on a console. One of them I'm looking at is using the Unreal 3 Engine. Idk if that helps.
Money Wise, I can pretty much upgrade any one part unless its CPU and Mobo to whatever is the latest bang for your buck. Anything the top gaming computers out there have.
New Soundcard would def be cool, but with this mobo I can only fit the SLI rofl >.<.
BTW you guys that have mentioned buying another 8800GTS I already have 2... do you mean 3?
10 out of 10 for spotting it is a pci-e 8x8 board, but 16x16 hasn't got much over 8x8 especially with something like a 8800
Like others have said, a sound card would help
Ya he has SLI already guys...
I would say 2 640 WD caviar blacks.
Or a new mobo, 750i,780i, or such. EVGA for brand.
And Windows 7/vista 64bit
chipset gave it away 650i.
And once you get a GOOD sound card you'll never want to use anything else. Not only for the quality, but that they actually get LOUDER than any onboard.
Originally Posted by ducrider
I would recomend a bigger hard drive for storage and get a GTX 260.
I'm with ya on the HDD
mrmikepan Going RAID 0 could be good, but i don't know without looking if your board has onboard RAID Controler
I love RAID 0, over 100MB/S read speeds
Sound cards are win, win
Sounds better, and takes work off of the CPU
Alright guys thanks for the help!
Oh btw... What speed RAM are people using now-a-days, RAM as improved SOO much with speed/price idk what the standard is now. If i was to do something with my RAM should I get 8gigs All 800Mhz Ram or go for 4gigs higher Speed.
Definately 4GB of higher (so 1066). 8GB is overkill anyway, even running Vista and gaming at the same time. If you're going DDR2 get 1066 or if DDR3 then 1600
~Powelly
niccce... ty for the quick reply. One more thing tho... Can you point out some Ideal RAM DDR3 on Newegg... I'm not good at knowing what has good timings/Mhz/PRICE mix.
No worries. With this upgrade, how much have you got to spend? 1000W PSU is beefy as so I'd defs tri SLI those 8800GTS's, and I recommend going for either an E8400 (3.0GHz but 45nm chip) or Q9650 (3.0GHz quad 45nm chip) which will both be faster, more energy efficient and cooler than your current CPU.
Raid that HDD!!!
i'd say get a gtx 260 or a 4870 and maybe a ep45-ud3p. Then sell your two 8800's with that 650i mobo to help reimburse yourself for blowing like 300 bucks.
Sell an SLI board for an UD3P? No way...
Why is everyone saying to Tri-Sli 8800GTS's?
Last time I checked you can not Tri-SLi 8800GTS's, unless you're referring to a stand-alone 8800GTS for folding or physX.
Correct me if I'm wrong though...
bigger hdd. 160gb is pretty low. And get w7 64 when it comes out (so save for that)
and illusion of progress is right. YOU CAN NOT TRI SLI 8800GTSs!!!!!!!!!!
1 - 20 of 26 Posts
