1 - 12 of 12 Posts
Taking it Easy
Woo! What are you going to put them on?
Originally Posted by Cyberbot
tape or glue.
Aren't they self-adhesive? The one I had peeled off and stuck on its own.
Discussion Starter #8
aww man i just realized that my pack is internal
I can only fit the logo on my cm690 window, I was hoping to put some on my case
actually i can't tell if its internal or not
Yes
I got a pack of them as well.
A few weeks later, I got a free lanyard. I <3 OCN.
The applique has an adhesive on one side.
You carefully peel the masking tape off the sheet of gloss paper and the applique should stick to the tape.
Then, you take the tape, with the applique still stuck to it and stick it to where ever you want it.
Apply some pressure on just the applique then slowly peel back the masking tape.
1 - 12 of 12 Posts
