1 - 17 of 17 Posts
just wanted to say i jsut recieved mah ultra x connect 500 watts. http://www.xoxide.com/x-connect-500-uvblue.html i bought it when it was on sale for $89.99 wooooooohooooooooo and i jsut had installed a couple of mins ago and so far im happy < can u tell? > hahahaha
Congratulations, I was happy when I got mine too
. It looks good doesnt it ??
hell yeahhhhhhhhhh i jsut got done fixing the wiring and damnnn its hellah niceeeeeeeeeeeee now i need to work on mah second project build me a clear case... and i mean BUILD my OWN the hell with buying a pre made one the best thing in this world is D.I.Y!!! so u can brag about and say I BUILT that ISH!!!! eehehehe
oh yeah do u know what they call that metal plate where the screws goes to? to hold all for walls ? i mean like that pre made plexiglass cases?
I think its called a case not sure though
lol do you mean what the mother board rest on the PSU what exactly do you mean?
Got mine earlier today too, I just don't like the fact that I ordered the really shiny blue when my system is all silver.. lol.
Other then that, its sweet. But it turns out, my PSU wasn't holding back my OC.. my RAM is.. lol, Now I think I'm screwed for going any farther. I can barely afford to buy the pump for my up and coming water system.. As a matter of fact.. I'm in debt for buying the PSU! lol
what i mean is theres this metal thing at the corner of the plexiglass where u screw in the screws that will hold the plexiglass siding.. god its hard to explain i'll jsut buy the damn pre-made case and take that piece out and ask home depot if they have it, and if they do ill return the damn case ehehehe..
customer return sure is a great policy hehehehe....
I thought the Acrylic/plexi cases were epoxied together? Oh well, you should be able to use any kind of aluminium or metal angle iron to hold the sides together, since it is a DIY project. You can get different kinds of angle iron from Lowes or Homedepot, cut it what ever size you want and drill the holes.
Discussion Starter · #9 ·
ok this is what im talking about http://xoxide.com/clearacatxca.html see that thing in the corner of this case theres this SQUARE thing where u screw the screws<<--confussing aint it?lol> i thought about what u said archer its just wont look good with it compare to that one im talking about.. god im confussing damn E.S.L...
Ok I did some research and found out that the corner brackets are not metal, they are actually Acrylic Cubes. You can find some here ---> http://www.tapplastics.com/shop/prod...54112033532503
Here is where I found out this info, http://www.virtual-hideout.net/revie...se/index.shtml, looks like the exact same case to me.
Discussion Starter · #13 ·
Originally Posted by xms
Whats the cheapest you can get an X-Connect 500w in the US for? Might try and import one this week.
well i got mah x connect from XOXIDE when it was on sale last week for 95.00 shipping and handling included, but the cheapest place where u can get it is here http://www.case-mod.com/store/index.php?cPath=29_104 believe me x connect is well money spent less clutter and looks so damn nicer compare to the rest of the psu ive seen.
Discussion Starter · #14 ·
So $99 isn't too bad then. Shipping is gonna cost me $35 tho
1 - 17 of 17 Posts
