Woot! Got my stuff!
977 Views 28 Replies 9 Participants Last post by  Spart
I'm so happy! I could use some help though. My memory is supposed to run DDR2 1000 and 5-5-5-12. As you can see it's not. The bios on this board is really confusing me because it's much more advanced than my old 939 board was. Any tips or walkthroughs on setting ram speeds and timings on this mobo? I know there are alot of you guys using it. I'm happy with my 3ghz cpu OC for now. I'll leave it here till I get my WC setup in my Rocketfish. I just want to get the memory running like it should and run 3dmark06 and run Prime95.
RAM: http://www.newegg.com/Product/Produc...82E16820146755
EDIT: Pic didn't show up. Should be fixed now. Also linked to my ram.
1 - 20 of 29 Posts
DDR2 8000 or 8500 are DDR2 800Mhz rams qualified to work on 1000 or 1066Mhz.
You need to put it at your own to 1000.
push it farther lets see how how the 9950 will go
go to 3.6!!!
you need to set your RAM manually to the designated speed that you want them to run at... remember to also set the voltage manually to the required level
Originally Posted by Timlander View Post
go to 3.6!!!
Yea if I can get 3.6 on a SB600 you should be able to no problem
Good luck testing on your New Parts
hey you got the same mobo as me. Im about to overclock my rig as well with my 9950. You said you got to 3.6 . Did you get any higher?
In fact your entire rig is close to mine lol.
9850 stock is 2.5 I dont think getting 3.6 on it, isn't that bad
.. I guess I could always push it more
What have you got your CPU at Timlander?
Mine is at 2.6 for now untill the rest of my water system comes in. =) here is whats here so far, the rest should be here by the end of the week:
What RAD is that? I have the MCR320 with the D-TEK Customs Fuzion V2
Good luck on your testing once all your parts come in
Black-Ice-GTX-480, its huge. Its about 20" long.
Awesome!
What voltage do you need to pull that off?
Volts that I used is 1.45
That isn't a ridiculous amount of voltage for a Phenom, right?
I wonder what that chip could do with ACC. It seems to be rather unique.
Hmm, your overdrive looks different than mine. Is yours a newer version?
The stock V for my 9950 is 1.3V. so thats only .15V more.
Ive had it up to 1.55 before on Vista 64 bit side.. I need more power to be stable at that OC......AOD version I have is 2.1.4
ok mine is 2.0.14. does it have its own upgrade utility?
Are you saying that you haven't stress tested the CPU? Or just the memory?
I must say, that is a really nice watercooling loop and a nice phenom you have there. My Q6600 can only hit 3.4GHz.
1 - 20 of 29 Posts
