1 - 20 of 21 Posts
I can't wait to see what this thing will do, I've got a 2.2ghz northwood p4 that ouroboros1827 sent me, he didn't know if it worked or not...and I saved it from getting exacto-knifed to death LOL
anyway I tested it in another comp of mine, and it worked. So I'm gonna pop it in the rig in my profile, and see what it can do as far as overclocking
Originally Posted by wowza
Sheesh you and those via chipsets, your breaking the law of Via chipsets being bad OCers.
LMAO!! Yeah, nice oc Chief. What was you old cpu?
I belive he had a 1.8GHz northy (400FSB) that he had to 2.4GHz stable (2.8 into windows) on that same board...Correct me if I am wrong..
yep! your correct, and if I had a better cooler and stuff, I'd have had that 2.8 stable, at least I believe so.
I bought this board for 40 bucks on ebay, it sells for like 60 everywhere else lol, so I think I have a good deal
EDIT: nevermind....they're discontinued now LOL
also...how good is the D1 stepping, my old p4 was a C0 or something...
The D1 stepping is intel's 4 Gen stepping (3G for your processor), so for your processor, they made a D1, C1, B0
it went B0 --> C1 --> D1
So It's the best stepping out of the 3. So yea, you got a sweet processor on your hands, and that 20 multi will add to that clock speed
The 2.0ghz northwood is a 20 multiplier. The one has has is a 22 multiplier which means even higher clock speeds
I've got some sisoft arithmetic and multimedia benchies I'll post them in a bit.
EDIT: Aaaand here they are!
ahh there we go, better
Heck my via chipset has overclocked my Celey 335 2.8 to 3.5 stable after 12hours of Prime95. Of course thats as far as the board will go due to the limited bios. 165 is the highest FSB it will go with a 533 chip.
Discussion Starter · #12 ·
alright, I broke 3ghz....just gotta see if its stable, I had to make the agp/pci 68/34, which isn't bad at all
cpu-z screen coming up
Discussion Starter · #14 ·
yeah I'm gonna keep going up with the voltage turned as high as it can go, and i'm gonna plug in numbers to see where I can go...I'm gonna try for 3.2ghz or something
Discussion Starter · #15 ·
Ok, I got a cpu-z screen of 3.0ghz. I couldn't figure out how to make a new verified oc thing..so I just took a screenshot. It's legit, I promise lol.
I also ran prime95 and got an error...but I think prime had a spaz, because occt's stability test ran through ok.
1 - 20 of 21 Posts
