61 - 80 of 83 Posts
Data Recovery Engineer
MOTM?
Dude those pics on the last page were sexy
Discussion Starter · #75 ·
Update
I have all the fans in the case now and have all the wiring running out behind the MOBO, just need to place the fan controller and led batch board to figure out what needs lengthing and what needs shortening so I have no excess/stretched cabling then I will go through and sleeve the lot I am thinking.... Maybe, maybe not on that one.
Re-fixed the Fusion res about 1" 1/2 / 2" away from the MOBO plate and lifted it about 20mm to eliminate kinking in the bottom hose and to bring it into better view. I had to open up the bottom mount with the help of the Dremel in order to make it fit over the thicker bottom section of the res, being as there is so many freaking grommets for cabling it makes fitting this where you want very difficult.
I will have updated pictures up today
My god does that look amazing
Discussion Starter · #78 ·
UPDATE!!!
Hey guys!
I should have some photo's of the rig fully assembled and powered uploaded today!!
Just the finishing touches left to go now
Some of the UV lighting I go is not actually UV, so I still need to get some Smaller UV lights to light up some of the tighter sections.
Other then that I just have the switches and window to install.
Looks awesome :D
61 - 80 of 83 Posts
