1 - 10 of 10 Posts
im sitting at around 49-50c
previous oc was 4028 @ 1.4v
tested/ing
1.450 volts cpu
+.025 nb vid
<2000 ht
~2450 nb
17x246 4182 - FAIL - BSOD
17x245 4164 - FAIL - rounding error
17x244 4148 - FAIL - rounding error
17x243 4132 - FAIL - fatal error less than expected
17x242 4114 - FAIL - BSOD
17x241 4097 - didnt even try not worth the extra voltage, this is getting frustrating
is the rounding error usually ram or cpu?
and what is the fatal error less then expected
Originally Posted by exzited;14099723
do if i only got 70mhz with .025 more v would i get +60 from .05 more volts? assuming its like a curve
We assume this is true, but it's different for every chip at every stage - Try it out
too tired tonight. i with amd was like intel. get 10000000ghz out of box no hastle
i think im going to start with 4.3 tomorrow with 1.475 - 1.5 v
Haha, The process is the same for Intel chips, overclocking isn't flip a switch and *SHAZAAM* your done, unless of course you want a average overclock. We know this, because like I said every chip is different so using the method that someone else used will probably not work for you - or anyone else. It's merely a reference point to start with.
Originally Posted by superste2201
Leave the CPU core at 4ghz (it's a good overclock) and try and bump the CPU-NB up some more.
You should overclock everything separately rather than using the bus speed. The 955 has a unlocked multiplier, you should use it.
It doesn't post with NB anything higher then 2500ish, I've maxed out on the NB and the NB vid volts and it still doesn't post.. And I only have multipliers of one not half so its hard to use them. Right now my NB is at 23xx it will jump straight to 26xx which wont post
1 - 10 of 10 Posts
