1 - 20 of 60 Posts
Hey all!
Im still a noob at this but this is what I’m planning. I am basically in my last year of college and will be going off to university this time next year, so I plan to build a pc that will last me thorugh it with minimal upgrades needed later on.
Also everything is funded out of my pocket so depending on work will affect how I get everything done. The colour scheme I’m going with is blue and black.
As I’m getting the parts I will be using my old pc and changing bits as I get them =/
At some point I will get a side window cut in and/or this picture airbrushed on.
Uploaded with ImageShack.us
Objectives
Have a computer to last me through university.
SSD for quick boot time.
Raid 5 redundancy.
To finally hit 4 GHz!
Please note that I am open to suggestions about kit etc.
Pc Components to get:
Obsidian 700D (Got)
Gigabyte GA-890FXA-UD7 890FX
AMD Phenom II X6 Black Edition 1090T (Got)
Corsair dominator GT ‘4GB to start maybe 8 later’
Corsair HX1000 or Corsair AX1200 ‘undecided’
HIS HD 5970 ‘6series vershions'
D-Link Xtreme N PCI Express Desktop Adapter DWA-556
Zalman 6 channel fan controller
*Please note everythign below here has changed now, read later posts*
8 X Scythe Gentle Typhoon Fan for the rads
3 X Xigmatek 140mm XLF-F1455 Blackline
Need help with this for sure!
3 x SATA 6Gb/s hard drives for RAID 5
1 x SATA 6Gb/s SSD for boot OS and main applications
Water cooling Idea
I’m fully open to what I should use and shouldn’t use!
*note* I plan to have dual loops for easily cleaning and to remove parts etc.
Loop one will go like this.
360 >CPU>pump/res>Mobo>360
I want to use 3/8†ID & ½†OD for this loop mostly to do with the mobo block that comes with the UD7.
The second one like this.
240>5970>5970?>pump/res>240
I think I’ll go with 3/8th again unless people think I should use ½†for this one?
Water cooling bits.
‘will change with ideas’
Loop one.
Loop two.
Final pic.
Can't wait!
Originally Posted by fshizl View Post
your gonna use a 240 on your 4 gpu cores... lol
im subbed, i am wanting to know temps on those 5970's after this is done.
Originally Posted by Onions View Post
yea you should use the 360 for the gpu's
Its only gonna be one 5970 for a while this is a long term project and yes I will probbaly have to mod a 360 in at some point but using a 240 will do for the mean time
lol! ahh okay, well atleast i wasnt the only one thinking of it haha...
check out my build if you want... you might see some hints or tips that might help you with yours
Discussion Starter · #9 ·
I will do in a sek
I still need help with fans and hard drives if anyones got any ideas?
R5 3600 / X570 Aorus Elite WIFI / EVGA RTX 3080 Ti FTW3
To the OP, why didn't you get this?
http://www.svc.com/ddcbaytwo.html
But, still I think it's going to look pretty good. That case is huge. I think the hardest part (of modding the case) was getting the lower drive bays removed.
Discussion Starter · #13 ·
Well as i said im still open to surgestions for the water cooling bit
So you never know i might still get it
· Unwilling Beta tester
Looks good.
You do know that the pump doesn't mount in that res right? You are going to have to find somewhere else to mount it, and you might want to look at getting an after market top. Also, have you seen www.specialtech.co.uk? I find that WC UK is often out of stock and don't carry the widest selection (they don't even have the EK supreme HF
Edit: Oh, and I would have a look at this review before deciding on an £80 CPU block.
Discussion Starter · #15 ·
Originally Posted by GingerJohn
Looks good.
Thanks If i got a dual bay/res and pumps which one would you surgest?
Il read the review whilest waiting for the mail man... if he comes today
You could get one of these, which will run two loops. It supports two MCP350 / 355 pumps, so the ones you picked are fine.
Discussion Starter · #17 ·
The Scythe GT's are great fans, Martin did a review of them here. The only problem is finding them in stock anywhere.
1 - 20 of 60 Posts
