Hi!!!
After looking for a new case with a lot of frustate ideas, I go to make and build my case.
I like some cases but all have some problem or don't like some point. Looking in Google I look EK Vulture, and I decided built case like this with my modifications.
Now I'm drawing in CAD program...
First I put components with my taste.
Option A
http://i.imgur.com/AWcZssY.png
http://imgur.com/rvQ4IwB.png
Option B
Problems...
Ram waterblock do interference with push-pull option...
I decide built Option A and I started yerteday to draw some sketches for frontal case...
http://i.imgur.com/bmbbBkA.png
Now, some 3D pieces modelings with frontal option decided.
Front cover (Acetal 7 and 10 mm with frost white logo):
http://i.imgur.com/9mT3SNO.png
Back plate cover (aluminium 2 or 3 mm):
http://i.imgur.com/V0KqSTv.png
And last, sktech for mount:
http://i.imgur.com/avOGjYS.png
Tomorrow I will draw back case.
Kind regards...
Option A
Option B
Problems...
Kind regards...
