Colour Schemes
1 - 20 of 25 Posts
Daniel Symonds
Hello just thought id start a work look and keep it updated in my progress if your interested .. also in my sig are some previous work logs i done
- some pics of the case as it stands.
Daniel Symonds
Discussion Starter · #2 ·
Extra Pictures
Parts so far . :
ATI 4890 (920Mhz)
TX650W PSU
Windows 8/7
40Gb Mushkin SSD
2x500Gb WD
1TB Spinpoint
ASUS P8Z68-V PRO Z68 MoBo
8GB 2x4GB CMZ8GX3M2A1866C9
Intel Core i5 2500K unlocked s
Alpha Cool 250ml Res
Update More Parts:
Samsung SE-S084F/RSBS Black Slim 8xDVD±R, 8x DVD±DL, 5xRam, USB BUS Powered Slimline DVD-RW Retail
1L Feser One Fluid - UV Acid Green for water cooling systems (Non Conductive < 10 ìS)
2.5m TFC, 1/2" ID - 3/4" OD Hose, Green UV Reactive
Alphacool Plexi lighting module G1/4 46006
Phobya 83063 Twin 5mm ultra-bright Green LEDs
FlexLight SMD LEDs - 30x 2mm SMD LEDs, Blue - 60cm long - with connection cable
1XSPC X2O Delta Intel i7 Only Mounting Plate
I was planning LC setup in this case, and your window cut shape reminds me of my project.
You can find many different worklogs with that case, but I never really seen anything with this kind of window shape. Here is my idea of LC loop:
- psu + most of cables are hidden (top area of the case is not exposed - look window shape)
- you can see entire loop through the window, rads and fans, nothing covered by anything, you see every single piece of lc loop, while stuff that is supposed to be hidden (psu, optical drive, wires is hidden)
- two very powerful 3x140
- easy to cut, no need to cut top of the case, and buy/ruin it with custom rad grill
- removed excessive 5,25 bays, two or one on top is enough for most of setups
Daniel Symonds
Poll added
Daniel Symonds
Discussion Starter · #9 ·
Still need more votes on paint
Daniel Symonds
need some more votes please
before i go and get the paint later today
I voted for "Other", Black internals, With white lighting and black tubing
, Would look rather nice and would suit the Lian Li style!
First off ... way sick caes
I voted for other
I like a black interior as long as it is done well.
I personally like clear hoses with clear liquid
Lighting as of now I would roll Blue / red since you have an Intell CPU / AMD card
Can't waith to see the results
Daniel Symonds
Discussion Starter · #14 ·
Thanks for the votes guys ... i have decided if i painted it beings its aluminium would probably scratch/look tacky quickly so i started polishing to a mirror like finish . i will post some pictures of the polishing and some goodies
Daniel Symonds
Discussion Starter · #15 ·
The Box
Daniel Symonds
Discussion Starter · #16 ·
more pics uploading
Any one got any suggestions ?
Daniel Symonds
Discussion Starter · #17 ·
Some Paint/Polishing Pics
Daniel Symonds
Discussion Starter · #19 ·
Small Update
Started Fitting some of the Watercooling (+ Extras):
Daniel Symonds
Discussion Starter · #20 ·
Update:
1 - 20 of 25 Posts
