1 - 20 of 110 Posts
Hi all,
This time ill upgrade my personal rig.
Updates will be also on my Youtube and Facebook named the same too.
https://www.youtube.com/c/TechMaxTV1
https://www.facebook.com/techmaxtv/
Watercooling - Bitspower
Fans - blacknoise.com - Startseite
Sleeve - Gosumodz
Thermal Compound - Thermal-Grizzly
PSU - be quiet
HDD - Toshiba
water transfer printing - MST-Design
The colorscheme I'm planning to go with is black/white/red.
I will go for a 480mm radiator in the top and in the bottom and a full watercooling loop with red coolant.
I will remove all the drivebays in the front and probably go for a dual reservoir.
Possibly I would do a custom acrylic glass window side panel.
Hardware:
CPU i7 5930K
Mainboard Asus Rampage 5
GPU 3x GTX 980 Ti
RAM HyperX Predator 32GB 4x8GB 3000MHz
HDD 4TB WD Green
SSD 500GB Samsung 850 Evo
PSU be quiet Dark Power Pro 11 1200W
Case Phanteks Enthoo Primo SE Schwarz/Weiß
Fans Noiseblocker eLoops
Watercooling:
22x Bitspower Blood Red Fittings 14mm BP-DBREML14
Bitspower R5E Monoblock BP-WBAIX99R5EFCBNPAC-CL
3x Bitspower VG-NGTXTITANX BP-WBVGNGTXTITANXNPAC
2x Bitspower Leviathan Xtreme 480 Radiator BP-NLX480-F2PB
2x Bitspower Water Tank Z-Tube 200mm BP-WTZACT200-CL
2x Water Tank Z-Multi 150 (Acrylic Version) BP-WTZM150AC-CL
Bitspower VGA SLI/Crossfire Bridge For 3 Slots BP-VGAB3AC-CL
Bitspower D5/MCP655 Dual Top BP-2D5TOPAC-BK
Bitspower D5 / MCP655 Pump Mod Kit - Abrasive Red BP-D5MA-ARD
Bitspower None Chamfer PETG Link Tube OD14MM BP-NCPLT14-L1000
Bitspower G1/4" Deep Blood Red TII Rotary Adapter BP-DBRTIIR-C
Aquaero 6
Mayhems Blood Red
Huge thanks to Bitspower!
Today i took some pictures. All blocks will be polished.
http://abload.de/image.php?img=img_1542spjq0.jpg
http://abload.de/image.php?img=img_1548c2jys.jpg
http://abload.de/image.php?img=img_1557amk61.jpg
http://abload.de/image.php?img=img_1559sckz8.jpg
http://abload.de/image.php?img=img_1560amkfk.jpg
http://abload.de/image.php?img=img_1564ankii.jpg
http://abload.de/image.php?img=img_15674jkws.jpg
http://abload.de/image.php?img=img_157173kn5.jpg
http://abload.de/image.php?img=img_1573fsjtr.jpg
PC Crazy Dario
To be honest, they look amazing just like this.
The part where water transfer printing didn't stick to the fan looks for instance like a wear out of too much usage and it looks cool. Don't know what you are aiming exactly, so...
I like the fans. I hope you can tune it in.
1 - 20 of 110 Posts
