Overview
Well i usually just get an after market air cooler for cooling my CPU, but this time i have decided to take the plunge for water cooling
Well its been about 4-5 months forgot to update this but i finished this a while ago works great
Plan
Mount the Radiator in the Antec 900 Hard drive bay and use the floppy drive mount for two hard drives.
[X]HW Labs Black Ice GTX Xtreme 240 Dual 120MM Radiator
[X]PT Nuke Copper Sulfate Biocide
[X]Laing D4 MCP650
[X]1 Inch Corner L Bracket 4X
[X] Silverstone 120MM FN121 Case Fan Black ~1200RPM 26.6DBA 53.24CFM X2
[X]Thermochill Mounting Screws 1-1/4IN for Closed Corner Fans (4 Pack) X2
[X]Primochill Polypropylene Tee for Water Cooling T Line 1/2IN Barbs
[X]D-TEK Customs Liquid F/X UV Dye Water Cooling Additive Visible Blue
[X]XSPC X2O Delta CPU Block V3 LGA775 AM2 CPU Water Block G1/4
[X]Danger Den Tubing Plug for 1/2IN ID Tubing (Single Plug)
[X]Masterkleer Pvc Tubing 7/16IN ID 5/9IN OD 10 Feet
[X]Distilled Water
Images
Mounting 2 Hard Drives with 1 Floppy Drive Mount
Mounting Rad in HD Bays with L 1 Inch Brackets
Final Product
