World at War
209 Views 2 Replies 2 Participants Last post by  Kryten
Worse framerates and crashes to desktop. What gives? I'm running on the 1.3 patch and Geforce 182.08 drivers.
1 - 3 of 3 Posts
lolwut?
What did you change? Worse framerates compared to what?
Not a right lot changed.
And I should've said, but compared to COD4.
COd4 gives me 92FPS constant, with a drop to around 80 in busy parts (mid-airstrike, loads of smoke grenades and explosions, you know the deal)
I simply mirrored COD4's settings. 1680x1050, 4xAF, Dual Vid cards, no syncing the frame rate etc etc. And AA filtering was turned way down (like on COD4) but my FPS is around about 50-60, which believe it or not, is unplayable at times and was pretty disappointing!
EDIT:
Worth noting my ping was 41, and at that latency, isn't ever a problem.
1 - 3 of 3 Posts
