1 - 6 of 6 Posts
AMD Overclocker
Hey guys, I currently have a scythe mugen 2 w/ push/pull gentle typhoon ap-15's. Would it be worth it to upgrade to a thermalright silver arrow? Would the temps be much different? Would I be able to oc higher?
I'm NOT new to Overclock
Missing a few details.
Fill out your sig rig
What temps you getting?
What is your OC?
I wish people could give more details rather than just a question with nothing for us to work with.
C
The Computer Guy
maybe very little temp change,remember on air ambient temps play a factor.
AMD Overclocker
Discussion Starter #4
I'm running a phenom II 720 unlocked to an x4. My oc is currently 3.5ghz. And my current load temps depend on my ambient.
Retired Reviewer
AMD Overclocker
Discussion Starter #6
Originally Posted by ehume View Post
You might get a temperature drop of 3 - 4c, max. Not bad, but worth the bucks? Only you can tell.
Eh, maybe i'll invest a little more for some water cooling. If I was to upgrade and spend that much money, I should be looking for at least a 10c decrease.
Of course, I would be paying more than just $80, but it might be worth it overall.
1 - 6 of 6 Posts
