1 - 6 of 6 Posts
· Banned
I have a card that had a cooler that snapped, the gpu itself is fine. Now... Sapphire accepted RMA request. Should I send it in wait two weeks for it to be possibly fixed or just suck it up and wait for UPS to deliver my replacement cooling solution, a accelero Xtreme on monday and ignore it.
Im going to put it on the replacement GPU anyways if I got one, I just am worried about potential resale value if I ever do sell it
I honestly cannot decide
the 7970 is plenty powerful enough for awhile and I'de imagine the next series would be a Tick rather then a tock for model lineups which wont be for awhile anyways.
· Banned
Originally Posted by truestorybro545 View Post
If the card is perfectly fine, why replace it? Just attach your new coolant on it when it comes.
I was also worried about getting a non-golden chip. I can load 1500//900 (I lowered this clock to get VRMs to cool down abit) stable 3Dmark'd at 1.35v so yeah, I just keep it and do that... but I would imagine they would just swap the HSF and Fan block and send it back. Sapphire wouldnt waste a $400 card I'de imagine.
If your temps are stable, 1.35V at such a high clock is good enough. It should hopefully get even better with a different cooling solution. I wouldn't risk a bad chip for that.
· Banned
Holy mother of multiposts.... I didnt even click multiple times
If you have a golden card, I dunno your typo on the clocks is confusing, but if you have a golden card, I would not take the risk by sending it back. You can rma it in the future. Just make sure you don't spoil anything with Sapphire, let them off easy.
· Banned
Discussion Starter · #6 ·
Sorry my english can be very derpy sometimes. I was pretty surprised by it myself actually! I went with sapphire to begin with because I wanted a CPU HSF + GPU and It was $100 less then a Lightning
http://www.techpowerup.com/gpuz/3vswa/
That clock wont run 3DMark properly, it eventually crashes about 5 minutes in...but 1500 is stable and pretty. (old GPUZ Validation) unless its normal for a 7970 to remain stable at 1500... then I dont have a golden card, but everyone else I know gets hit with artifacting even trying to set theirs to 1500~2000 lol.
1 - 6 of 6 Posts
