1 - 12 of 12 Posts
Just curious if a cheap WC system would beat my AC Freezer Pro 7. Would it be worth it and would there be a visible difference? Would even the cheapest water cooling be better than air cooling? thanks
What price are you thinking cheap?
And can you please fill in your system specs under user cp.
Since when has the freezr pro been a good air cooler? Its a decent one nothing like the big boys, i didnt like it. What $100 water are you talking about?
SNERP!!!
Prebuilt kits (except for Swiftech or DD) are bad. Lap that HSF and you'll be happy.
Originally Posted by JacKz5o
Nope, a good air cooler is better then even a $150 W/C setup.
That isn't true. The Kit in my sig will beat a BT. You can't judge a setup by just the dollar amount.
No, A cheap WC kit might not even be as good as a good HSF...
Find a water cooler that performs better than my lapped Ninja+. For a total of 50 dollars including the better fan I get 30C MAX on a warm day 100%load. Here is a picture of 33hrs of two stress prime04 aps runnig at the same time... my temps while running are only 25C.
I remember when......
That is impressive Villan, what are your ambient temps for that?
In deference to Snerp, I think it should be stated that good air will beat any cheap pre-made kit
You can certainly put together a cheap custom system that will beat the Freezer pro.
SNERP!!!
You got my back
1 - 12 of 12 Posts
